Poo kill switch on SBA or RMK???
I'm on my phone and can't search the forums.
I have a 2012 SBA and want to put a doo kill switch on. 2013 setup from poo is just too expensive. I will plan to just abandon the kill switch on my throttle block. If I order the switch for the ski-doo is it basically a plug and play?
Anyone who's done this can you give me some specifics, and a photo would be great! I'm wondering if the wire connections are similar, I can solder if need be. And if the wires to the thumb warmer run seperatly than for the kill switch, and if it is just a standard two wire hook-up?
The whole switch is expensive...
You just need to pull the stock Polaris kill switch out of the housing and put it into the Ski Doo 515177310 kill switch mount... You will need to trim a bit of plastic on the mount itself to allow for the wire path and extend some wires but it will work for Less than $10 in part ... I highly suggest getting the screw with the plastic mount it's $2. But fits just right # 250000263....
