Polaris XLT Rebuild
Bought an XLT for $600 as an intro to snow machines. Grew up riding ATVs my whole life in AZ. Moved to AK a few years ago and missed riding something with a motor.
Came across a running XLT with 3K that needs a bit of love but I figure its a good way to get to know it before I trust it. The compression checks out at 120 in all 3 cylinders. I don't plan on rebuilding the motor but the exhaust seals have been shot for a while depositing slug in the bottom. I have heard about the crank failures with these (95 and 96) but am planning on easier flat trails for the most part, not mountain climbing for now.
One worry I have it that is leaking coolant from I assume the water pump but we'll see. So far I plan on:
-cleaning the fuel tank, new lines, rebuild pump, cleaning carbs, new needle/seat
-cleaning oil tank, new lines, checking oil pump
-Flushing the coolant system and possibly replacing water pump
-replacing chain oil.
-cleaning out air box
-might replace the steering tie rods
-greasing all the zerks
-order new wind shield
-Fortunately the track looks like its in good shape
My question for you all is what else do I need to do, look into, replace, clean, inspect, etc????
Looking forward to the resurrection!!
heres pics
Crank issues were on earlier models and with the addition of triple pipes. It created weird harmonics that took a toll on cranks. With that being a 95 or 96 with only 3000 miles I would just fix the leaks and run it. My only concern with it would be leaky crank seals causing a lean condition. Those were pretty bulletproof engines if left stock, I have seen several with over 10,000 miles and never been opened up. One of them had 18,000 miles before compression got low and needed rebuilding.
Be sure to check all bearings and don't forget the jackshaft and driver bearings. Other than that, go ride it.
