polaris underhood goggle bag on 13?
JoBoo
Anyone try the polaris underhood goggle bag from the 11/12's on the 13? Now that the engine structural supports are carbon fiber they don't have the same holes that the 11/12's had. I haven't taken the hood off yet to see if I can get it to work, wondering if anyone else has tried. I really liked that bag so hope I can still use it.
It does not work the way the directions would have to install because of the carbon fiber structure that you stated. Let us know if anyone found a good way to install.
The only one I've seen is the new goggle bag that sits above the hood and relocates your gauge. I assume that is a replacement.
Before Polaris had one I just zip-tied the Arctic Cat one to the supports.
Worked great for two years no problems.
i put the bag on my 13. i did not use the "bar/"stick" that came with the bag. instead i made sure the velcro was tight, a zip tie and tightened er up.... fits perfect with goggles in or out, and shouldnt be worried about it falling down.
I've posted this before on other Polaris goggle bag threads but this may help others. I drilled a small hole in the tab for the hood fastener that the bag also uses. I then filed a small grove in the hole and installed a small ty-rap to keep the goggle bag tab in place when reinstalling the hood.
