I got a Polaris teather and was wondering what wires I hook to on my sled which is a 16 axys
The matching empty plug right under the bars?
Mount it in front of the switches.
Don't use the metal washer.
Add a #6x1/4" long wood screw in the rubber cap to help keep the plunger pressed in fully. Threaded into the rubber.
Use a small amount of dialectric grease in the cap.
The above things make it a very reliable tether.
Hey sheetmetalfab, have you had issues with the actual Poo tether? I have had issues only with the aftermarket versions with a RED rubber plunger. Issues were as you stated above with the center striker mushrooming out and making contact sporadically. I've had nothing but good luck with the OEM Poo version and had them on the last 5 rides with zero issues. I'm only wondering if the screw is preventative or if you've actually had the issue on the black plungers? I do like the dielectric grease idea
I had to use the screw in my Polaris (black) plunger before my sled ever even saw snow. No BS. Since putting in the screw, however, it has worked flawlessly.
Hope my ProArmor keeps working, I know lots of guys have had issues with them.
Last time I used, and had probs with the Polaris one, it did not kill the sled, and is why I went a different route...
My plunger was either deformed and sticking or freezing in the run position.
I had a little grease in it, for same reason you mentioned.
Back when I used them, the only time it would get exercised is when if I fall off, otherwise I'd unclip it from my coat. I hated plugging that thing in...
It prob got moisture in it from sitting or getting washed, causing it to freeze, or maybe bound up from lack of exercising it.
After that particular day, I just said screw it and went a different route.
Someday, we'll be lucky and have a fail-proof snow compatible tether. Hopefully.
I've never used one without a screw.
The washer causes issues also in not letting the plunger get depressed enough.
I've heard of a bunch of pro armour tethers sticking open after the clip is pulled. This allows the sled to keep running.
If the poo tether fails it turns the sled off.
I'll stick with fail/safe instead of fail/crash.
