Is this motor a CFI-2 or is it a CFI-4 ?? The difference is 2 injector vs. 4 injector
Not sure how many miles since the possible previous failure but fuel pressure or lack of volume from partially obstructed an fuel filter and or dirty injectors have surfaced a few times. I would highly recommend having the injectors flow tested and ultrasonic cleaning done by Dr. Injector and replace fuel filter. Then after its all back together verify proper fuel pressure.
Also verify correct TPS adjustment and function along with proper oil pump adjustment. I have come across a few oil pump cables that have cracked at the adjustment threads which allowed way too low of oil consumption.
Poor quality fuel regardless of time of year is also always a possibility.
