I have a complete 2003 ProX 600 136" track that I am parting out. Great running sled.
throtle / Kill switch block $ 25.00
throttle cable $ 5.00
ignition switch w/ key $ 10.00
choke cable $ 5.00
coil with plug wires $ 20.00
Torsion bar $ 5.00
Tunnel Heat Exchangers $ 15.00
exhaust pipe stock $ 60.00
exhaust silencer SLP ceramic $ 100.00 only two year old, no rust, this the newer quiter one
Y pipe $ 30.00
brake hose $ 5.00
Speedo $ 15.00
Tach $ 15.00
Hood - red w/ graphics no cracks $ 75.00
steering post $ 10.00
Head Light Assy. $ 15.00
wire harness $ 45.00
Steering linkage $ 15.00
Brake caliper $ 10.00
belt Guard $ 5.00
speedo pick up $ 5.00
jack shaft with disk $ 5.00
speedo cable $ 5.00
spindles and steering arms $ 15.00
cover aftermarket black $ 45.00
Primary Clutch without weights $ 75.00
front bumper $ 15.00
fuel pump $ 10.00
weights $ 20.00
Front Heat Exchanger $ 25.00
Left Trailing Arm - silver $ 65.00
Right Trailing Arm - silver $ 65.00
CDI $ 30.00
shroud $ 5.00
rectifier $ 5.00
Carb rack TM40 $ 50.00
belly pan brace $ 5.00 Belly Pan - Red no cracks or holes $ 65.00
Brake handle assembly with controls $ 35.00
Chain Case and cover $ 75.00
Secondary Clutch - Team Secondary For Keyed Drive shaft $ 100.00
windshield bag $ 10.00
2 front shocks Rebuildables $ 75.00
tie rods both - red $ 10.00
rear bumper $ 10.00
left side radius rods upper and lower - red $ 10.00
Right side radius rods upper and lower- red $ 10.00
Handle bars straight$ 10.00
Oil Tank / air box $ 15.00
coolant tank $ 5.00
Sly Dog Skis - Black with 8" shaper bars $ 130.00
Rear ProX Skid with - 136" extensions $ 325.00
Rear ProX Skid with out extensions $ 250.00
136" rail extension w/ offset axle and wheels $ 75.00
Tunnel extension $ 15.00
Track -136" 2" lug $ 350.00
complete 600 motor -top,bottow,reeds,recoil,mounts $ 650.00
Complete Bottom end $ 350.00
Complete Top end (Jugs,Pistons,Head) $ 300.00
All parts are list plus shipping from 49417. I will make deals on multiple parts. Pick up welcome. PM me here or email me at nicholsgh@att.net
choke cable $ 5.00
Torsion bar $ 5.00
Y pipe $ 30.00
brake hose $ 5.00
Speedo $ 15.00
Tach $ 15.00
belt Guard $ 5.00
speedo cable $ 5.00
fuel pump $ 10.00
weights $ 20.00
CDI $ 30.00
shroud $ 5.00
rectifier $ 5.00
rear bumper $ 10.00
coolant tank $ 5.00
