B
I have a ton of polaris parts I need to move out.
97-01 700 cases $150
1-220 cylinder $200
1 780 slp big bore cylinder with piston, $200
edge 700/800 carb boots $30
97-01 cdi/coil pack $150
wedge belly pan, with newly powdercoated hood rails $75
purple front springs off 97 700 rmk
secondary clutch with slp dial spring mountain helix for twin pipes $75
97-2000 carb boots for keihin carbs
set of keihin carbs off a 2000 700 rmk, set up for slp single,w/cables $75
ski shock black w/purple spring new $45 15 3/4 center to center on eyes
hyvo gears 19,20,21 top gears and 2 39t bottom gears $15 for top,$30 for bottom also 70 pin hyvo chain $40
01 gen 2 red seat $75
gen 2 headlight, no bulbs $15
stock bulkhead and tunnel coolers for 97-99 rmks,bulkhead cooler will fit to 01
a couple of recoil housings, and water pump housings.
97 700 flywheel $35
01 800 flywheel $35
xtra 10 skid with fox shocks and hyperfax $200
97-99 wedge footrests
00-01 trailing arms mounts(inboard)
97-98 oil tank,coolant tank
xtra-lite 136 rail,I have a pair, one is good, the other has a small flat spot from going through the hyfax, but is still usable. $75 for both, great if you have one bad rail, or put on new hyfax and you'll never know.
1-220 cylinder $200
97 700 flywheel $35
01 800 flywheel $35
