SOLD
Details on the sled are:
PRO RMK Skid, black anodized rails
VE boondock tunnel/bulkhead
153" x 2.25"camo extreme
Black Plastics
White hood, speedo, air intake kits
Drive shaft with Avid 3.0 7 tooth Combo drivers, ntn bearing
Gears 19/42 74p chain
Black Cyclone master cyl with lightweight rotor
Pro Taper Bars
Seat
8.8 gallon tank
Walker Evans Front Shocks
Powder pro skis with carls cut
Avenger III gauge with tach, water temp, max recall, 30 second record and egt's (egt's probes included but not installed)
39" Z-Bro's A-arms and hardware
Black Z-Bro's Spindles
600 HO engine, PERC reverse, case ported, V-Force Reeds, timing bump, pistons & crank are new, motor is set up for premix but can have oil injection added.
Coolant bypass kit
600 RR pipe can
Indy Dan balanced primary was new when installed
Balanced TSS04 Clutch
Black Plastics
Pro Taper Bars
Seat
8.8 gallon tank
Coolant bypass kit
600 RR pipe can
