T
Photo #
4 Polaris edge RMK/ Ryde Fx rear shocks, back rear is 17’’ eye to eye by ¾’’ X1 ¼ ’’ Front rear is 12 ½ ’’ eye to eye by 1 ¾’’ X 1 1/8’’ . Front rear is in good condition and the back rear needs to be serviced.
5 Polaris edge liberty 700/ SLP power dome heads for high altitude.
6 Polaris edge/ New 4” power madd black pivot style handlebar riser.
7 02 Polaris edge 800 liberty/ CDI .
8 02 Polaris edge 800 liberty/ CDI wiring harness.
9 03 Polaris edge700 liberty/ CDI part # 4010718
10 03 Polaris edge 700 liberty/ CDI wiring harness.
11 SLP/ Polaris edge vents and bags.
12 04 Ski Doo Rev/ foam kit.
14 Polaris edge 800/ P-85 clutch missing the spring and outer sheave has some dings, still works.
15 Polaris edge liberty v.e.s. 700/ cylinder with good jug but needs new nickel seal.
16 Polaris edge liberty v.e.s. 800/ cylinder with good jug but needs new nickel seal.
18 03 700 Polaris edge liberty/ Stator, ignition part # 4010297
19 Polaris edge liberty/ Pulley, recoil catch part # 3021144 qty.3.
20 Polaris edge liberty/ Fly wheel water pump drive part # 5630824. qty. 3
21 03 700Polaris edge liberty/ Water pump and housing.
22 03 700 Polaris edge liberty/ Pull cord set up with housing.
23 Polaris edge liberty/ Oil pump with pickup tube on the top.
24 Polaris edge liberty/ Oil pump with pickup tube on the side.
26 00 Polaris Gen II rmk/ gas tank.
27 Polaris/ team clutch spring part # 7043063.
28 04 Polaris edge/ speedometer, trip button is missing all other lights and gauge work.
29 Polaris/ p-85 used clutch hard wear. weights 10-58, clutch button new, shims, washers, weight bolts new, instructions, rollers & pins.
30 Fly/ handlebar Pivot mount 2 ¾ cross bolt holes.
31 Polaris liberty/ Reed boots.
32 02 Polaris edge liberty/ fuel pump.
33 01 Polaris edge liberty/ engine mounts.
34 04 800 Polaris edge liberty/ reeds.
35 04 800 Polaris edge liberty/ water jacket.
36 04 800 Polaris edge liberty/ stator part # 4010297
38 04 800 Polaris edge liberty/ coolant pipe.
39 04 800 Polaris edge liberty/windshield.
40 04 800 Polaris edge liberty/ thermostat housing.
41 04 800 Polaris edge liberty/ P-85 clutch bolt.
42 04 800 Polaris edge liberty/ pull start set up with housing.
43 04 800 Polaris edge liberty/ water pump and housing.
44 ski doo/ ski left.
45 Polaris edge/ rear shock bars.
46 Polaris edge/ stock front shocks with yellow springs used but still work.
47 Polaris edge/ rear axel fits many other sleds 13’’ X 19.8 mm.
48 Polaris edge - ski doo/ track idle wheel mounts 25mm. qty. 5
49 Polaris edge/ speed sensor.
50 08 ski doo xp/ side vent.
51 power madd/ throttle extension.
52 Polaris edge/ idler wheels with bearings, red 5 ½’’ , isd 25mm qty.4
53 Polaris edge/ idler wheels with bearings, black 5 ½, isd 25mm qty.2
54 Polaris edge/ idler wheels with bearings, black 6 ¼, isd 20mm qty.2
55 Polaris edge/ idler wheels with bearings, yellow 6 ¼, isd 20mm qty.2
56 Polaris edge/ idler wheels with bearings, red 6 ¼, isd 20mm qty.2
57 Polaris edge/ idler wheels with bearings, black 7’’, isd 25mm qty.2
58 Polaris edge/ idler wheels with bearings, yellow 7’’, isd 25mm qty.2
59 Polaris edge/ idler wheels with bearings, red 5 ¼ , isd 25mm qty.1
60 Polaris edge/ idler wheels with bearings, yellow 5 ¼, isd 25mm qty.2
61 Polaris edge/ new Parking brake lever and spring.
62 Ski doo Rev/ front shock.
63 144 Polaris edge/ Left side rail for track.
64 Polaris edge/ Heavy duty rear track springs.
65 04 Polaris edge RMK/ Hood silver.
66 01 Polaris edge RMK/ Hood black.
67 Polaris edge/ Light housing.
68 Polaris edge/ Can mounting bracket.
69 Polaris edge/ fly wheel 14 deg.
70 Polaris edge/ handle bars with side hill strap.
71 Polaris edge/ coolant heat exchanger.
73 04 800 Polaris edge/ cylinder head 85mm ¾ deton and water jacket.
74 Polaris liberty edge/ coolant pipe engine clamps.
75 800 Polaris edge/ reeds.
76 Polaris edge/ rear torque arm axle 17 ½’’ X 18.6mm with 5 ½’’ wheels.
77 Holtz racing control arm 15 ¾’’ ball is 1’’ wide. qty. 2
87 Holtz racing steering arm 10’’ ball is ¾’’ wide. qty.2
79 Polaris edge/ upper control arm.
80 Polaris edge/ lower control arm.
81 Polaris edge/ steering rack.
82 Polaris edge/ track tension bolt set up. qty.2
83 Polaris edge/ steering rod 10 ¾’’.
84 Polaris edge/ boggy wheel caps black. qty.3
85 Polaris edge/ rear track axel.
86 Polaris edge/ rear skid guide rail tips.
87 Polaris edge/ new parking brake lever and spring.
88 Polaris edge/ ski spindle.
89 Ryde Fx/ Shock, rebuild able 17” eye to eye works good but has a broken top mount.
90 Polaris edge/ front bulk head.
91 800 Polaris 144 rmk edge/ complete chain case assemble.
92 Polaris edge/ extra long bar cover for raised bars.
93 Polaris edge/ reveres kit comes with team clutch, cdi, all wiring, and brake assembly that has the reverse button on it.
94 SLP/ boost bottle.
95 Polaris edge/ drive axel with cogs (drivers).
96 Polaris edge/ rear rack.
97 Polaris edge/ exhaust can out put cover.
98 Polaris edge/ fuel pump.
99 Polaris edge/ rear bumper.
100 Polaris edge/ voltage regulator.
101 Ski Doo rev/ track limiter strap adjustment brace.
102 Polaris edge/ brake caliper.
103 Polaris edge/ coolant bottle.
104 Polaris edge/ throttle assembly.
105 Polaris Gen II/ air box.
106 Polaris edge/ Y pipe.
107 Polaris edge/ steering rod (left).
108 Polaris edge/ steering rod (right).
109 Polaris edge/ steering rod (center).
110 Polaris edge/ Variable exhaust valve parts only missing the guillotine. qty 2
111 Polaris edge/ Variable exhaust valve. qty 2
112 Polaris edge/ Air box.
113 Polaris edge/ Pull cord handle.
114 Polaris edge/ Ignition coil.
115 Polaris edge/ Brake clapper hold down.
116 Polaris edge/ Front shock mounts.
117 Ski Doo Rev/ Clutch cover.
118 Polaris Gen II/ Clutch cover.
119 Polaris edge/ Clutch cover. qty 2
120 Polaris edge/ Rubber clutch bolt cove.
121 Polaris edge/ Rubber boot for steering rood. qty.2
122 Polaris edge/ Rubber hood hold. qty. 2
123 Polaris edge/ Ski loop (yellow). qty.2
124 Polaris edge/ speedometer gauge.
125 Polaris edge/ Rpm gauge.
126 Polaris edge/ Bar riser 4 ½’’ with bar clamps.
127 Polaris edge/ Pipe stock.
128 Polaris edge/ Jack shaft with disk break.
