Hey I got a 2020 axys 850 with 1,000 miles. It has developed a rattle a little bit off idle. I have tried lots of things to figure it out but can’t seem to pinpoint it. Any help/ideas would be appreciated.
Usually a roller in the primary.Hey I got a 2020 axys 850 with 1,000 miles. It has developed a rattle a little bit off idle. I have tried lots of things to figure it out but can’t seem to pinpoint it. Any help/ideas would be appreciated.
Just see if you can spin one of them without removing the cover or spring.
After the roller bushing is gone it leaves a gap and allows that weight to rattle at idle and below engagement rpm.
I need to figure out how to post a video on here. So you guys can hear. But it’ll do it at higher rpm’s as well come to find out.Usually a roller in the primary.
I took the exhaust valves out to check them out and I found this scoring on the pto side. Is this too much. I need to get valves cleaned. And put back together and do compression test?I need to figure out how to post a video on here. So you guys can hear. But it’ll do it at higher rpm’s as well come to find out.
