A
agurdo17
New member
ok have to check with u guys on this one cause the number im getting seems kinda crazy.
i mounted the dial indicator and pointed it to the pto end right at the end. i pulled it over until i found the lowest spot and set the indicator to zero. then i pulled the sled over until it got to the highest spot and it got to the line before 10. which is .009? at that measurement i do not know how the sled is still together considering the tolerance is .0025. Did i do this right?
