Polaris 800 155 clutch and gears
B
Big_T_Roose
I am building a Polaris edge with a big block 800 and a 155x2.4x15 track. I would like to know what clutch setup both primary and secondary, and i would like to know what gears i should be running. I am running 7 tooth exo drivers.
I am running a team roller at low altitude. I also need a good set up for 8,000 to 10,000 for the one time i am out west this year. I got 7 tooth from Wahl Bro racing.
Above 8k black/red team secondary spring 66/44 helix or 60/42 helix, almond spring and then whatever weights to get your revs right. If it's got an slp single on it, something like 10-62s.
At low altitude, same clutching but with probably 10-66s or maybe even go heavier.
sled_guy
sled_guy
Do you know the spring rates on those springs?
my guess is you can run what we run with the cfi motor with the slp single...polaris black/purple spring(160/240) w/ 62/42/.46 helix, black spring(140/330) with 10-68 or 70 at sea level(I use mtx 68 with 2 gram in the tip, 1 gram in the middle)or 66-68 gram belly busters work also...all at sea level to 3000...
All right can anyone tell me what team roller cam e on a 04 polaris switchback? Or how can i tell a difference between the TSS-04 and the TSS-98. I think it is the TSS-98.
