Just got the sled back together and it sounds great! I drilled a couple of holes in cap, temp fix until I get a new one. I ran a wire in and out of the PTO oil line to create a small bubble, so I could the watch the oil move. It moved as I let the machine idle, so I assume my pump is now pumping. I know 100% that cap was not venting correctly. I just hope that was the cause of my motor failure. Hundo- thanks it makes me feel a lot better knowing that the lower end is ok. I check for vertical movement in the rod and could not feel anything. If I had lower end damage wouldn't the rod bearing be the first to go? since it is bathed in fuel. Thanks for all the input
