C
Timing Module off a 2011 or 2012 Pro RMK 3 degree. It worked with a BD turbo kit. The kit was installed on a 2013 PRO and the plug is different for the E Key.
picture below is not the key but a file photo from the Boondockers site.
$50 shipped in the US. $50 plus shipping into Canada.
BoonDocker’s line of electronic timing adjusters allow for a simple plug-in timing adjustment. Timing remains unchanged at low rpms and timing retards progressively as rpm’s rise towards max rpm. By retarding ignition timing the E-Key is able to effectively reduce the chance of detonation so the engine can run more boost, compression or at a lower elevation on the same or lower octane fuel. E-Key’s are available for ARCTIC CAT and POLARIS machines and are available in 1, 2 or 3 degree timing adjustments.
![674-4765-IMG_2255.png](http://boondockers.com/images/ProductImages/Thumbnail/674-4765-IMG_2255.png)
