Pol Low eleavation pol
snobyrd
Has anyone tried the pol low eleavation clutch kit for 850 na, If so , share your thoughts. I tried the 60 44 helix today with the blk purple at 5500 feet and i was pretty impressed , great bottom end and excellent backshift with great top speeds. The doo tbo guys took notice off my sleds performance today.
I ordered mine with the low elevation kit just to try something different, big mistake as its a complete dog...Not enough spring and too much helix and weight.
The Q2 just cant support it.
Anybody down low need a low elevation kit?
what elevation are you at?
I had to get the low elevation kit to ride around home... ~800ft above sea level.... Seemed peppy enough but have only been able to get 1 break in ride on it, not doing anything exciting. It started pretty poochy but I have about 2.1 hrs on it now and its starting to liven up. Was taching out at 8350, no idea what the track speed was. It beat the '19 155 850 off the line and out pulled it every time when toying around on the trails... fwiw
Much higher here, run around from 4-7000. But I was always having to add weight on previous sleds, this is my first sled with Q2 as I missed buying a sled in 2021.
No big deal though, I will send this stuff to my Bro in Northern Ontario and I have a Dr. John kit and a TRS kit, will try both and use the one I like the best.
My son would swap u.
Where u located??
Thanks guys, I have a couple solid options on my work bench already. Was more of a failed experiment on my part.
