Ron,
Not picking on you buddy JMO on this.
![Smile :) :)](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
![Beer :beer; :beer;](https://www.snowest.com/forum/images/smilies/beer.gif)
I truly think the design of these valves was meant to be a variable system. The solenoid from my understanding was added for emissions reasons and prevents that. I can see that with enough pressure the valve may flutter at best until the solenoid closes.
It looks like a band aid to me.
![Roll eyes :rolleyes: :rolleyes:](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
Again JMO. If they truly wanted it either open or closed, why wouldn't they ditch the rubber bellows and use a true solenoid operated system mounted on the motor?
![Confused :confused: :confused:](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
The more I look at it and study this system and take into consideration how other exhaust valve systems work they are all variable. Holding the guillotine closed until a set rpm doesn't necessarily make sense in my mind. As rpms increase so does exhaust flow and pressure.
The variable exhaust system was originally designed to create more low end response. This was to combat current pipe design. Manufactures were able to develop larger belly pipes that focused more on high rpm HP. With a variable exhaust system they could inherently change exhaust port height.
Which is the opinion I have and the point I'm trying to make. A constantly closed valve cannot adjust port height through different throttle openings.
By 6000 rpm you are easily at trail cruising speed. If those valves aren't opening you are going to create way too much heat in the valves and stifle proper exhaust flow. At least that is how I look at it as it sits on my work bench.
If you are an on/off throttle type of rider I doubt it would really matter either way. Full throttle in deep pow or climbing I doubt you would notice it. However, if you run partial throttle, or do slower tree crawling this could really benefit. I would think you would notice it in roll on throttle situations. And possibly on/off/on throttle when rpm is allowed to drop below the magic solenoid closing rpm.
I'm also taking into consideration how we changed springs on the old system to get them to open sooner and more completely at higher altitudes. It is just my thinking that they may be opening too late. For as easy as it is to test I still think it is at least worth trying.
Anyone care to take a test light and see what rpm the solenoid is triggered????
Sorry for my always lengthy reads. Hope it was at least informative to some. Please chime in with any conflicting thoughts as this thread has been great for getting the gears turning.
![Face Icon Small Happy :face-icon-small-hap :face-icon-small-hap](https://www.snowest.com/forum/images/smilies/old/face-icon-small-happy.gif)
Cheers all and Happy Holidays.
