Running at altitude I would start with the pink spring. If you are above 8000ft all the time you may need to go with the yellow, but I would start with the pink.
Thanks for chiming in Ron. Everything you stated is correct from what I understand.
I'm not here to argue any point, and I'm not even sure this is worth noting. I just wanted to state my interest in this in the first place. Note, these are just my thoughts open for discussion.![Big grin :D :D](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
As we all know, what the dyno says and what happens on the snow are two entirely different things. However, I found this interesting. FYI Dynotech is in New York at sea level.
According to the dyno, the surge is quite possibly being caused by the valves opening too soon! This would be in conflict of what we are seeing from the guys who have actually tested this on the snow. The dyno showed a drop in HP and then it quickly started to rebuild when the valve timing was off. Note the surge. My concern is of the opposite. If the valves are being held completely closed until X rpm it is keeping too much heat around the exhaust valve and port area. Going back to the old way allows the valves to operate gradually from exhaust pressure working against spring pressure.
The more important issue was letting off at WOT the valves really needed to be held open longer. Again, this is accomplished the old way. When they closed immediately it caused a rich condition and the possible burble/stumble some people experienced when getting back on the gas.
The hole thing just seems buggered to me. Who came up with this darn diaphragm operated thing anyway? Japanese two strokes have been using mechanical exhaust valves for ever. Yamaha was using them before they retired the two stoke sled too. I remember dirt bikes in the 80's all using mechanical systems. This system just seems kinda flawed to me, but again I have been exposed to a lot of different two strokes over the years.
I've never been in a position until now that I even thought about changing how it worked. Sorta tells a story right there huh. ![Stick out tongue :p :p](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
