Please Help!!!!!!
Can someone please tell me where this plug in goes on my 08 RMK Dragon 700
I recently replaced the whole motor with another one and I for the life of me can't remeber and can't find the other end for this guy.
It is pig tailed and splits off to,each top injector. Everything works and runs fine but with this not being plugged in my check engine light is on. Any help would be awesome.
Thanks in advance
Look at the air box side of the throttle bodies on the left (clutch) side. The TPS unit is a black plastic unit attached to the throttle body and the plug goes in from the bottom.
Yep.. TPS PLUG...
It's a tight fit.. But might have to reroute ur wire harness to reach it.. if you have already zip tied the wiring harness down.
