A
Hey.
Anyone seen this
Is that due detonation like I suspect?
I think my fuel pressure drops for some reason on 7000rpm starts puking and bogging and sputtering when I really got in to boost. Got one capture done from the boondocker box and it said rpm to be 10970, is that even possible?
The most annoying thing is that it run pretty nicely last winter. https://www.youtube.com/watch?v=96S_zwep69c
This one is perfectly running motor before piston change. MAG side No damage to cylinders
![](http://i1138.photobucket.com/albums/n522/Antti_Tammela/DSC_0107_zpsuwesm7ez.jpg)
This is from 50km after piston change. Cylinder failure on PTO side.
![](http://i1138.photobucket.com/albums/n522/Antti_Tammela/IMG-20160110-WA0004_zpsdgviqieu.jpg)
Ideas what to check:
Sensors?
Stator?
Fuel pump voltage?
Injectors?
Cabling?
Air leaks?
I have fresh set of cylinders and pistons. But just want to be sure that I don't do more damage.
My setup is:
- Boondocker racegas kit, low pressure actuator on wastegate.
- Boost tee 9 psi of boost, running on neste 98e5 fuel
- Intercooler
- greddy bov
- 2 degree advance key on crank
- 3 degree e-key to retard
- 800 2008 stock motor
- Walbro high cap fuel pump
- bdx external fuel regulator set to about 35-38psi on high idle
- innovate lambda gauge
- koso fast egt probes
- about 89grams of weight on MDS turbo weights. yellow/white spring on clutch
- 38/44 cpc helix with green white spring, in that video there was totally original 2011 m8 snopro driven on place
- 2008 original gearing on diamond drive
Anyone seen this
Sensors?
Stator?
Fuel pump voltage?
Injectors?
Cabling?
Air leaks?
My setup is:
- Intercooler
- greddy bov
