How the heck you suppose to put in these piston clips ? Ya, they make a tool... Whats the garage way to get 'em in ?
The 06' piston pin/clip opening has a ramp right before the grove where the clip seats... i can get it in there no problem,, but needs to make it over that ramp...
I experimented with my old 05' by putting a socket which has the OD of the opening, and quick rap with hammer and it went in. Marked my old piston while testing.. Is this a way to do it ? Maybe tape it up before rap.. ?
Problem is doing that on the 2nd clip when on rod.
The trick to putting the second clip in on the rod is to not do it on the rod. I install the 2nd clip on the bench and then only need to install 1 clip per piston on the rod. I find it easier to install the inside ring on the bench so on the mag side piston, I install the PTO side clip on the bench and on the PTO piston, I install the MAG side clip on the bench.
