I have a 2010 M8 which I recently turbo'ed with a used Cutler stage II kit. Now that I have an Air/Fuel (AF) gauge I can see there is a huge lean spot on the factory ECU map from about 3000 RPM to 4000 RPM. It doesn't run really well until 5000 RPM and up. The AF gauge goes from 13.5 to 14.2 up to 3000 and then buries itself past 17 during this lean spot. I am using the Attitude controller because it is simple. I also own a near new PCV which I added back when I piped the sled. The sled always had this low end bog and now with the AF gauge I know why. Here's my thought - the PCV plugs in at the ECU and the Attitude at the injector. Why can't I run both and use the PCV to fix the OEM map and the Attitude for the boost functions. I know Dynojet now offers a Bosch 3 bar boost sensor so you can run a wide band O2 sensor and map by AF ratio but there are no maps available yet. Does this make sense? Anyone else find this black hole in the OEM map?? Thanks!!
