Phazer on NOS
TreewellDweller
Has anyone put the new BOSS NOS set up on a 4-stroke phazer? Can it handle the 60hp shot for any duration? Is there a progressive way to have the NOS kick in such as from 2/3 or 3/4 throttle to full throttle? I've got a 2007 Phazer with a 151" track and I'm thinking of going to a 159" and would love to make it a better boondocker sled. Any info would be greatly appreciated.
you start doing more than 30hp shot your on a fine line, run 30 hp shot and be safe by staying within the 15hp per cylinder rule. If u run a larger shot than that, theres an increased risk of wrecking something, and its not cheap nor easy to fix like a 2 stroke.
I really appreciate the input. The fella at BOSS didn't see any problem but I think he also mentioned that he hadn't actually installed one on a Phazer. I'm glad I've thrown this out there.
I would sure like to hear from anyone else that has had some experience on this.
THANKS!!
i used to have a phazer and i did some research into puttin nos on it. i think you will be fine with 30hp shot. With proper throttle control it can really make a phazer shine but it could also get you stuck alot more often if you think that holding it to the bar then hitting the button will get you out of jam or put a higher mark on the hill. Throttle control makes a huge difference in how well these sleds get around in the deep and steep.
