Wondering if I have a pg turbo running 100% av gas would I run out of octane before max duty cycle on injectors and fuel pump? I would be mostly 4000-8000ft. What do u think the max boost pressure would be safely. It would be on a 11 m8 and reason I ask is I don't want to run rg no problem with av just don't think I will gain a whole lot with secondary injectors unless I run better fuel. More fuel same octane to me doesn't equal more boost and if my fuel maxs out before my injectors is there any point in complicating the system with more injectors. By the way is a timing key to save your bacon because you forgot to turn the boost down on your way to the truck cause I see people adding them but if you are retarding your timing you make less hp so u don't deto but up at elevation you shouldn't need it and if you think that because of the timing key you can add more boost you can but I would think you r making less hp. So if your at say 12 psi then the key retards your timing you would make the same numbers at lower boost without the key correct? I have more questions but I think I'll hold off for awhile. I am new to turbos as you can tell just trying to wrap my head around it before I buy my first kit thanks for your input it appreciated.
