Issue started towards the end of last season where I started getting minor and inconsistent bogging when carving on right hand side and rolling onto throttle. It was easily overcome by brapping throttle. Sled would sputter a bit and then no problem.
Dealer was not able to help because issue could not be reproduced on dry land but suggested changing TSS and kill switch, which was done and no change (I used TSS bypass device and when that did not result in any change I re-installed my existing TSS).
Dealer suggested DuraPro magetic tether maybe faililng so I tried running without it connected at the wire harness and no change. Re-installed tether.
Dealer suggested fuel filter may be distended and letting in air but I have not yet tried replacing the filter as this occurs on a 3/4 full tank of gas. I'm not sure if it occurrs on a full tank. It does seem possible the issue correlates to a less than full fuel level but does not explain this:
First ride of the year started with a 7 mile road ride and 2 hours of technical climbing into a riding zone (lots of careful route finding, minimal WOT, lots of starting/stopping engine). Issue did not occurr the entire time until we arrived in the riding zone and first right hand carve into WOT the issue started.
More noticeable this time was stalling at idle that seems to accompany the bog. Bogging starts, and the sled will inconsistently sputter and eventually stall at idle. Sometimes it will idle smoothly.
MOST interesting was this (which occurred once last year and I'd forgotten):
Tested compression this year and both sides are ~148. A little over 2300 miles on the sled.
Left to my own devices I'm going to trace all throttle and ignition-related wires and check for faults.
Will again try riding with TSS bypass and tether disconnected to ensure those variables are eliminated.
Will replace fuel filter.
Appreciate any insight or suggestions anyone has to offer.
![Victory hand :v: ✌️](https://cdn.jsdelivr.net/joypixels/assets/8.0/png/unicode/64/270c.png)
- Sled is stopped, leaning slightly downhill and to the right, handlebars turned fully to the right
- Sled stalls
- Withouth changing anything, able to start (e-start) and idle sled normally
- Sled stalls immediately on applying throttle (no increase in RPMs achieved from idle)
- Able to re-start and idle normally
- Change nothing else at all except straighten handle bars without changing the position of the sled
- No stalling, throttle behaves normally
