Performance package
2
So what's everyone's input on performance packages.... I was looking into the pa head and CPI single pipe setup... But I also was looking into the bmp package a well... Any input or experience.? I'll be running 0-4000 feet and it's a 2012 switchback assault 800
That combo is a pretty dang good setup . I have sold a few of them and work well. The hps and my head are a less $ option that is the biggest bang for your buck period.
Brad
The head and can really wakes them up. Brad if we run the pipe do we have to run a fuel controller or is it still bolt on and go.
So do you run the CPI pipe with the HPS can? Package sounds just like the SLP Stage 3 kit so I have to imagine you need a fuel controller. Keep the feedback coming. Thanks.
Joe
Fuel controller is needed with a pipe and head.
Are you seeing the same results with the SLP pipe?
Slp works great also probably only 2 hp less than the cpi but fit and finish is better. Imo
Joe
No the pipes come with there own silencers. The hps is not designed to run with either pipes just the stock pipe.
Brad
Stock pistons with the head? And also is there a provided map if the CPI combo and pa head is bought
Currently I have quit carrying the cpi as they are into building summertime stuff at this time . So all I have is the slp setup ,and yes i have a map for that one also. Brad
brad, are you using the map developed by slp or your own? if it is your own, would it be possible to send it to me? for the pcV. thanks
pv
pv
I bought the slp pipe, pcv and pa head from power addiction and it works really well. Was riding yesterday in two feet of fresh. My buddy who owns a 2012 pro climb 163 and mine is a 2011 rmk 155 lined up at the bottom of a good hill. I took off the line and pulled away to at least 3 sled lengths. We both compared rides and felt that my sled was way stronger on the bottom and midrange the cat was noticeably stronger wide open throttle.
are you using the slp map? or is the map brad's? i have the same setup. the slp map is very safe to say the least. just wondering if brad has made any changes.
pv
It is the map from slp, if it is a little safe I will take it, a little safe than sorry for me :)
pv
P/V it is the slp map it works great. If you need it let me know Brad
