Looking for specs on Engine mounting...Belt deflection, Offset alignment, Clutch alignment, Crankcase Stop adjustment.
My Engine plate came in the other day from Fastrax, I have fresh mounts all around and also went with the Push Arm/Torque arm setup. I would like to make damn sure that this engine is mounted correctly this year, and clutches are aligned properly. I think with the plate I will be up slightly higher than stock? Any info is appreciated.
Thanks in advance
Thanks in advance
