R
ramairtransam
New member
Guys, first off, Merry Christmas everyone. I have an 700 none VES XCSP that I put a PERC kit on late last year. I bought the kit off ebay and it was designed for an 03. I bought a reverse pumping oil pump and just put newer carbs on it because my original ones didn't have a TPS sensor. I wasn't able to get the bugs out last year because we ran out of snow so I put it on the backburner until this weekend. It runs great, great low end performance, but I'm having problems above 3/4 throttle or above 7500 rpms. I used my stock mag but installed a 3 degree advance key. Also, I got a newer ignition switch with the premium option to fit the wire harness. Basically it feels like it's misfiring and completely out of power at wide open. If I back off on the throttle a bit it clears out but once I hit about 7500 on the tach it bogs and gurgles. I know I should be running a newer mag (18 degree) but I've heard of people adding PERC to an older sled and just using a advance key. Can anyone think of something I'm missing? Also, it seems to run a bet better when I turn the key to the premium selection.
