Perc not working after turbo.
adam5187
I just finished an install of silbers kit, and now I dont have reverse. I know the kit should not effect perc function, and I have made sure the perc button is working with my meter, and it is plugged in. It worked when I first started the sled, now it isn't. I have never had to mess with the perc system, so if anybody has any ideas I would appreciate some input. Thanks.
Had the same problem, turned out to be a TPS adjustment problem. You are more than likely going to have to calibrate your TPS.
or your idles set to high. blades should be set between .0025 and .004 max, very sensitive adjustment. I believe that the perc is affected by both the tps and idle speed.
How do I adjust the tps? My reverse won't work now well it a craps shoo if it will. This was after I had to gap my plugs down to 8-9 thousands..
