PCV Maps
PC-3 MAPS
Does anyone have a good PCV map for a 2007 dragon 700?
Thanks
DYNOTECH Jim (585) 993-2777
www.dynotechresearch.com
For the $25.00 per year membership to all of his dyno reports, he'll provide the maps.
He DYNO-tested a 2008 D7 with stock and SLP single pipes and created the maps from that dyno test
If you have the re-flash done to yours, I'd recommend the LEANer of the 2 maps.
If you didn't get the re-flash, I'd recommend the RICHER of the 2 maps, which is the map I'm running in my 2007 D7.
I usually run at 1200' elevation, Stock my plugs used to be BLACKER than black ALL the time. The mid-range used to have a "hit the kill switch type effect" because it was so LEAN, now that's been cured, drives down the trail much nicer. I've run that map for the past 2 seasons and am very pleased with it.
The maps are for a PC-3, so you'll have to manually input the #'s input your PC-5, should only take a few minutes to do.
Hope this helps
Thanks. Jim did call me back and emailed me a map so I am good to go. I guess he is just a very busy person.
Polaris and all their issues sure keep him hoping :)
