I am looking for a PCV map for a 2009 Polaris EFI4 Assault/Dragon 800. I have the update but am still using the 2009 Flash. I eventually plan on getting an auto-tune done with the PCV but am looking at some other maps. I also have a modded pipe (similar to Bikerman) and a high compression head. Anyone want to share some of their maps. If you need a host for the file, you can e-mail me:
milehighassassin at gmail dot com
I'll host the file for your and share it on here. Please include your sled info, mods, temp, what kind of fuel you run, etc.
I know Jim has some maps on his site but I am looking more for people that have other maps or have changed their maps for their needs. Figured this would be a good resource for everyone.
Maps so far:
2009 Polaris Dragon built using auto-tune (SLP Single, SLP Intake) (SCARTER)
2005 Arctic Cat M7 with SLP Twins (Scarter) Read the following about this map:
Maps so far:
Here is a copy of the M7 SLP twins map that I built. The map worked well but right before I sold the sled I found out that it had an "Injector perfector" one of those fuel restrictors that went in the fuel line to reduce fuel flow. So this map may be a little rich for the sleds that don't have the fuel restrictor but should still run good, just a little safer.
