Hey guys. I have a 2012 proclimb 800, i bought a ovs stage 2 kit for it and a boost it fuel controller, and its running like crap. at wide open around 8-9psi it has a major bog and just falls on its face. im running the koso afr and boost guages, my afr keeps flashing lean at wide open. i keep loading up the fuel on the top end to try and bring it down but it barely makes a difference. im up around 19-20 afr. so i have some questions.... how can i tell if my extra injectors are working? is cutting the stinger out of the stock pipe a must for these sleds? IF i dont have my plugs gapped now that its boosted would that be a cause for the bog? what is the ideal fuel pressure? im running about 39psi. Im just mind boggled, i dont know what else to check..
just some more info on the sled, im running straight avgas around 5-9000ft and around 8-9psi boost.
Also, if anyone else has installed one of these kits on their proclimbs please respond to this thread as i have some installation questions and concerns id like to discuss!!
thanks!
thanks!
