PC5 maps
lord7
Hello, I have an 07 dragon 700 motor in an IQR chassis and haven't gotten it completely dialed in yet with the new pc5 due to an injury. I was wondering what maps you guys are running and maybe letting me try them. I have a custom kit with a KPA 2860 and an intercooler. Running around 7lbs at the moment with 50/50 av gas. Any information would help.
Thanks guys
How far have you gotten?
In the reading I've done on the pc5 pti Is they already have a fuel increase per pound of boost set, and the user can change it. I had assumed previous that it would need to be started from scratch. How close is that part of the map? I have a Boondocker 700 turbo have thought about going this route.
PCV PTI
I've got a couple complete maps that I've created from scratch, I was mainly curious of someone else's mao just to see if their mid range is better than mine. I have a small bog in the mid range that I've been trying to work out and I got really close at the end of the season before I had an injury. Yes, there is a pressure table and from what Dynotech Research and other have told me, 2 strokes are suppose to have all zeros in that table, they automatically compensate fuel with each pound of boost. I had a dobeck before that fried itself, so going this route with the PCV has so far been really great for me, so far it's been changing the fueling accurately with changing elevation.
Lord7
I tune mine only with the pressure table and no bogs. One thing you might want to play with the the accell pump feature for quick throttle stabs. You can configure it to pull fuel for a split second.
PCV PTI
Thank you Boston Racing, i ll definitely try a map just using the pressure table, I didn't know about the accel pump, but I'll have to look into that as well!
