pc III clutching on 08 700
R
raymonddean03
New member
hey sledders,
i'm thinking about getting a power commander III for my 08 700 Dragon 163. i already have v force reeds, ceramic coated stock pipe, hps can, 19/42 gears, SLP intake, lots of vents, and a fire and ice headlight/intake, running the stock clutching set up with 2 derlin washers in the secondary clutch. I ride from 5-9k ft. any advice here on clutching would be great.
hey sledders,
I have a 2007 DRAGON 700 with a PC 3
Since the PC-5 Was just made available 2 weeks ago along with AUTOTUNE, I am going to install that shortly, and I would STRONGLY encourage you to go that route.
www.dynotechresearch.com (585) 993-2777 cell, Jim Czekala
PC-5 $369.00
Autotune $250.00
thanks kraven i'll probably get the pc 5 after knowing that. whats the autotune all about? what weights and springs should i use with my set up?
Autotune pc-5
Auto tune comes with an 02 sensor, all you do is plug in the desired AIR/FUEL ratio (let's say 12:1) after that it's FULLY AUTOMATIC, adjusts fuel as you drive, it's been around for a while for Harley's and ATV's, just came available for sleds 2 -3 weeks ago.
As far as clutching goes, I ride the U.P. (approx 1200') so I wouldn't be able to help you with that.
Good Luck with that PC-5/Autotune, I think you'll be impressed with it.
PC5 with AutoTune?
I am thinking of a turbo or NOS applications on my sled (07 DRAGON RMK)with the PC5 and Autontune. Does anyone know if this is compatable with these or have this in use with a Turbo or NOS? (I like the idea of being able to input a A-F Ratio and just let it do it's thing..)
