Patriot 850
C
Jan 24, 2017
31
2
8
I currently have a 850 Patriot RMK with a 163X3. The only thing not stock is the SLP PIcnic'r. Can you make a recommendation on what weight to run at 3000-6000 feet with the magnum force weights? i have the blue/pink spring on order for the primary. I am probably 260 lbs all geared up to ride if that makes a difference.
Thanks,
go high fast
1,547
467
83
Missoula MT
good job on converting back to Polaris and good job on the blue/pink spring. i recommend these for clutch weights and start and experiment between 68 and 72. i clutch for a bit of over-rev on the trail so off trail spring boondocking and climbing in heavy soft snow you should be right on the sweet spot especially with the 3 inch track and at 260. Good, clean and well aligned clutches with a good belt........priceless!!
for 6000 to 9000 i run the blue/pink spring at 66 year-round and love it.
https://www.startinglineproducts.co...magnum-forcetm-clutch-weight-for-polaris.html
