PARTING OUT: COMPLETE 2008 Crossfire 1000 with 144
As title reads....parting out a complete 2008 Crossfire 1000 with approximately 2200 miles. Anything and EVERYTHING available and will put complete parts list and pic's up shortly.
- Willing to ship items at your cost. Located in Lloydminster, SK.
For now....
- Motor - top end under 300 miles, comperession 135 psi both sides (videos of motor running and active compression test) - $1500
- Track BRAND new, never even seen snow 144x2" camoplast Challenger - $650
- Diamond Drive, Mechanical reverse with BDX Bearing upgrade - $500
- 2011 Mountain lightweight M Seat (all black, NEW) - $300
- 2011 style M fuel tank - new with gauge - $200
- Fuel pump with BMP adjustable regulator/gauge - $185
- Stock style fuel pump - $125
- 2011 Primary Clutch NEW - $400
- 2008 original used primary - $200
- Secondary clutch with BDX rollers and Speedwerx Helix -$250
- Front A-Arm and Spindle assembly, Platinum silver - $250/side
- Fox Float Front Shocks with gaurds - $350/pair or $200 each
- Rear Skid with 144" extension, fox shocks, new sliders, no damage - $400 Complete
- Vented Side Panels (all black) - $200/pair
- Hood - Orange, no cracks/scars, 100% complete with all hardware, wiring, lights, frog skins, speedo, breather, = $700
- Hood BARE - $400
- Headlights - $65/per or $100/pair
- Speedo Cluster - $275
- Front Bumper and Black Breather assembly modified with Mo-Flow front breather vents, 3" Neck tube, Frog Skinned stock box = Worked REALLY well for mod applications/etc
- Speedwerx Performance Pipe and Y-Pipe (EGT holes in), High heat black - $350
- BMP loud Exhaust Can (Black) $150
- Power Commander 5 Control unit - $250
- Throttle bodies with tested TPS and injectors - $500
- T-bodies separate w TPS - $250
- ECU - $475 (Triangle)
- KOSO dual Screen EGT (Fast Response) - $300
- Injectors - $175
**Can do up complete SPX performance package for 1000 Cat (Works GREAT)...this would be 1500-3000ft...Secondary Clutch with SPX helix/BDX rollers/etc, SPX primary spring and weights, Power Commander Fuel Controller, SPX Pipe and Y-pipe, KOSO EGT's, AFR Gauge --- sold in peices = $1300+ ... buy together = $1000 all in.
Thats off the top of my head for now. It's all there so if you need something ask and I'll shoot you a price
bong_6@hotmail.com
1-780-808-4239 (Mike)
