![112-1_zps21151aeb.jpg](http://i895.photobucket.com/albums/ac153/tylerbing12/112-1_zps21151aeb.jpg)
![113-1_zpsda2af610.jpg](http://i895.photobucket.com/albums/ac153/tylerbing12/113-1_zpsda2af610.jpg)
![114-1_zps76e2e8d9.jpg](http://i895.photobucket.com/albums/ac153/tylerbing12/114-1_zps76e2e8d9.jpg)
![115-1_zps0020fa5f.jpg](http://i895.photobucket.com/albums/ac153/tylerbing12/115-1_zps0020fa5f.jpg)
![116-1_zps2cc0c1dd.jpg](http://i895.photobucket.com/albums/ac153/tylerbing12/116-1_zps2cc0c1dd.jpg)
![117-1_zpsf4d43f70.jpg](http://i895.photobucket.com/albums/ac153/tylerbing12/117-1_zpsf4d43f70.jpg)
im going to part this sled out this summer for sure, but if someone needs and engine to finish there season off i will sell it now and start parting it out early. here is a list of the parts and prices. i will ship withing north america.
i have priced these as i would have normally threw my shop, i will consider reasonable offers and package prices. the sled will not be parted out untill the end of march unless the engine, track and rear suspension sell prior. due to a sled trip planned for march 22nd with a group of friends.
i dont mind holding items for people who dont mind waiting untill the end of the month
engine 250km on complete rebuilt with brp crank $2000.00
exhaust pipe $150.00
slp y pipe $50.00
slp can $75.00
secondary clutch $150.00
primary clutch $ 600.00 (this is fully rebuilt, as of feb 27th 2013. new rollers,ramps bushings ect)
stator $200.00
flywheel $150.00
carbs $250.00
rave solenoids $50.00 pair
dpm $50.00
computer with key $400.00
voltage regulator $50.00
chain case and cover $150.00
chain and gears (hyvo) $100.00
clicker shocks fully rebuilt with ti springs $400.00
top a arms $40.00 each
lower right a arm $75.00
seat $200.00
skis $200.00
skid $500.00
track 162X16X2.5 camo extreme $500.00
drive shaft with 7 tooth avid drivers $200.00
fuel pump $35.00
ignition coil $45.00
slp 6-8' head $250.00
steering post $75.00
spindles polished $25.00 each
riser block $40.00
pro taper bars and clamp kit $100.00
brake caliper $60.00
brake master $100.00
brake line $30.00
fuel tank $100.00
wiring harness $80.00
trigger coils $50.00
throtle block with lever $30.00
oil pump $50.00
all plastic body work with the wrap $500.00 (side doors,hood,front bumper,lower nose,dash,console has slp vents and flow rites)
chassis with regi $600.00 with coolers $400.00 with out coolers
coolant tank $40.00
oil tank $50.00
air box $50.00
recoil $100.00
nitrous kit $250.00
speedo $75.00
jackshaft $50.00
brake rotor $75.00
tie rod with ends $40.00 each
rear cooler $175.00
front cooler $100.00
v force 3 reeds $125.00
nitrous fueling station with 14lbs in the bottle $300.00
