Parting out a 2005 Polaris 975 Carls Cycle 159"
diamonddave
Chilly’s Mentor, SMF's Kryptonite
Parting out a 2005 Polaris 975 Carls Cycle 159".
The sled has 1700 total miles on it and only 200 miles on a new top end done by Fastrax. An electrical problem that turned out to be a broken ground wire (inside the case) in the TPS wire harness was chased and the following items were replaced BRAND NEW, TPS harness, hood harness, complete main harness, chassis capacitor, Stator, Voltage regulator, hand warmers and TPS sensor. Unfortunately, a couple thousand dollars of parts and labor were installed into this sled when $200 for TPS and connector was all it needed.
Sled has the 731 VR in it BTW
Other features are 159 2.4 track ported by Fastrax, Holz skid and Fox Floats on all 4's, 2006 SLP single pipe, Fire N Ice air box, Push arm torque stop, SLP pull torque stop. All venting including side panel vents, Tri city's bumper, skid plate, black hand guards, scratchers, SLP ski's, Holz spindles, 3" bar riser, New seat cover and more. Over $25,000 invested!!
Let me know what you want. Please PM me as I am real bad about not checking these kind of threads.
Here are some pics of the sled
The following items have already been sold
Side panels
Primary
Secondary
Avid Drivers
FnI Intake
Plastic Console
Holz Skid
Front floats
Track
Seat
Spindles
This is the updated list of what has been sold
Side panels
Primary
Secondary
Avid Drivers
FnI Intake
Plastic Console
Holz Skid
Front floats
Track
Seat
Still have
06 SLP pipe, Y, and can
975 top end with good lower end that has been case ported by Carls
top end has 200 miles on it
Stock A-arms with steering links
TCP bumper... will sell with all good plastic so if yours is still good you could resell your plastic without cutting your plastic
Hood, light, all wiring harnesses (200 miles) all electrical parts like stator, voltage regulator, capacitor
Stock uncut boost box
09 Spindles (200 miles)
Tunnel-bulkhead
Jackshaft, brake assy,
SLP powder pro skis, need new carbides
Side panels
Primary clutch
Secondary clutch
Avid Drivers and driveshaft
FnI Intake
Plastic Console
Front floats
Track
Seat (gave away)
Sway Bar
09 Spindles
Complete Holz rear skid 159 with fox floats
TCP bumper... will sell with all good plastic so if yours is still good you could resell your plastic without cutting your plastic...Bonus
Still have
06 SLP pipe, Y, and can. the weld on the outlet pipe of the can has a small crack, could be tigged no problem.
Stock A-arms with steering links/radius arms
Hood, headlight, all wiring harnesses (200 miles) all electrical parts like stator, flywheel, voltage regulator, capacitor, TPS
Tunnel-bulkhead
Chaincase Assy (stock cover) 18-39 gears
Jackshaft, brake assy, Oil tank, Coolant Reservoir
PM WITH REASONABLE OFFERS
how much you what for the TCP bumper?
I need to trash that plastic one anyway...lol
plus im starting to build my parts pile for later
$200 plus shipping with all the plastic includes the shock tower vents. Most guys have trashed plastic anyway or if yours is still good, you could resell your plastic and make most of your money back. These are the best bumpers for the IQ's...
