Parting out a 2000-2001 mxzx 440 race sled AND ALSO SKI DOO XP PARTS!!
SKI DOO REV XP SUMMIT X 2009 ALL BLACK SEAT NOT THE CRAP HARD 08 SEAT NICE SOFT 09 SEAT 250
SKI DOO REV XP TORSION SPRINGS AND SHOCK SPRINGS 80.00 SHIPPED FOR ALL 3
Torsion Springs and Center Spring for 2008-2009 SC5 suspensions. Torsion spring are next size stiffer than stock, and center spring is 135lb spring rate ( stock is 110)
Torsions
503-191-614
503-191-615
Center Spring
503-191-879
cooler cover for the new 4-tec sleds 28.00 shipped brand new
The below parts are off a 2000-2001 MXZX 440 ZX Race Sled
Track is SOLD
Shocks Piggy Back shocks and springs from the front rebuilt this summer 325 shipped
Rear shocks with spring on the center shock 225.00 shipped
Secondary Clutch with stock Helix 100 shipped
Hood Black with only one small crack in the front that is like 2 inch’s long 140.00
Hood Black Screens 25 shipped
Chain Case with 21D top gear and 43D bottom gear and chain complete with cover 100 shipped
Seat has some tears in the back right corner but can be repaired 120 shipped
Trailing Arms they are the reinforced ones for the Race sleds 120 each shipped
Spindles 30 each shipped
Brake assembly with pads, disk, caliper, and brake master cylinder 120 shipped
Clutch Cover 25 shipped
Skis and 6inch Carbides 150 shipped
Belly Pan Yellow with a crack below the clutch 100 shipped
Belly Pan Yellow outside Clutch Cover 20 shipped
Front Bumper Assembly 60 shipped
6 135 bogey wheels 10 each shipped
4 165 bogey wheels 15 each shipped
Headlight and headlight cowl 50 shipped
Tachometer 60 shipped
Speedo with 1700 miles with Speedo cable 80 shipped
Rear suspension without shocks and wheels everything there including the torsion springs and straps 250 shipped
Rear Bumper 10 shipped
Snow Flap 10 shipped
Drive Shaft 75 shipped
LH and RH consoles by your knee’s 10 each shipped
Center Console 10 shipped
Clear Gas Tank Gas Cap 50 shipped
I have a lot more stuff and will get pictures ASAP and if you need anything else and I also do you have PayPal. This sled was a roller and has everything other then the motor, carbs, primary, clutch and wiring.
Or you can call me at 612-919-1935 adam
Torsions
503-191-614
503-191-615
Center Spring
503-191-879
Track is SOLD
