seth25
Parting out 2005 Yamaha Viper Mountain. One cylinder, crank, crank cases are damaged. Let me know what you are interested in. Simmons Skis, 151" track. Machine has around 3,000 miles on it.
Blue/Grey Simmons skis $175
Primary clutch $200
Cylinder with piston $175 (2 available)
Speedometer $125
Front Shocks $100
stator $40
flywheel $20
carbs $50
cdi $40
secondary $50
chaincase with gears and chain, non reverse $50 (2 sets available)
recoil $20
airbox $20
jackshaft $20
front bumper $20
Upper radius rods $20 ea
powervalve with cable $40 (2 available)
powervalve servo $30
headlight $25
Speedo sensor $10
Choke Cable $10
Snow flap $20
Ig switch $20
Carb boots $20
Belt guard $20
Fuel pump $20
Coils $30
Wire harness $30
Head $30 (2 available)
Motor mounts $20
Brake caliper $20
Rear heat exchanger $60
side heat exchangers $40ea
Primary clutch $200
Speedometer $125
Front Shocks $100
stator $40
flywheel $20
carbs $50
cdi $40
secondary $50
recoil $20
airbox $20
jackshaft $20
front bumper $20
headlight $25
Speedo sensor $10
Choke Cable $10
Snow flap $20
Ig switch $20
Carb boots $20
Belt guard $20
Fuel pump $20
Coils $30
Wire harness $30
Motor mounts $20
Brake caliper $20
