parting out 2003 mountain cat 900
i am parting out my 2003 mountain cat 900
give me a call or email with anything you want or need 208-430-2431
or justinomaughan@hotmail.com
motor has newer top end
air box 50
belly pan left 50
belly pan right 50
belt guard 10
brake caliper 25
brake rotor 20
carbs 150
chain case gears and chain 75
cdi unit 250
chain case guard 15
drive shaft with sprockets 100
engine mount 25
exhaust valve condensor 50
exhaust valve regulator 50
front bumper
front rear shock 100
handlebars 75
heat exchanger left 50
heat exchanger rear 100
heat exchanger right 50
high rise brackets 100
hood 125
hood nose piece 20
jack shaft 40
ignition coil 35
lower left a arm 50
lower right a arm 50
luggage rack 30
motor 1200
Stock pipe 50
primary clutch 200
rear axle with wheels 50
rear bumper 30
rear rear shock 100
rear skid
reeds 75
seat 100
secondary clutch 75
servomotor 75
skid plate 50
Simmons Skis 250
SLP pipe and can 250
speedometer 10
speedometer cable 10
spindles-left 30
spindles-right 30
steering post 25
stock front shocks 75
tachometer 50
tailight 15
tarp 80
tie rods 20
track-162"camoplast 350
torsion Springs 75
tunnel and bulkhead 150
upper left a arm 50
upper right a arm 50
wiring harness 50
windshiled 40
