Parting out 1998 Arctic Cat Powder Special Limited 600 EFI with 156 and Vanamberg tunnel
Have Green ZR skis with purple loops $100 pr plus shipping
Snapped the crank last year and have decided to part this one out and move on to a new project.
Located in Snohomish WA 98290
Can send pics as needed. All in good working condition
Make an offer on the whole sled if you like before it’s sold off
Have the following parts to sell and probably a few more
Brake caliper 100
Brake rotor 40
Case, Engine 200
chain and gears 19T & 40T set 50
18T gear 10
40T gear 40
Chain 10
coil 50
Computer 300
flywheel 70
Front A arms, upper and lower 40 each
Front shocks, Fox recently rebuilt 120 pair
Fuel injection rail with injectors and Regulator 150
Fuel pump assy 150
gas tank 50
Head, shaved 15 thou 50
Headlight assy 50
idler wheels 5 each
pistons, 2 100
rails, extended for 156 track 150
Rear suspension skid, with Fox shocks 250
recoil pull starter 70
reeds, stock (almost unused) 40
Skid plate Purple 40
Skis, ZR both 100
speedo 50
Spindles 50
Steering Post with mounting bearings and blocks 50
Tach 50
Throttle bodies 50
Track drive shaft and drivers 100
53 gram weights - set stock A/C 40
Boss Seat SOLD
chain case, both halves 60 SOLD
Clutch, primary 100 SOLD
Clutch, secondary 100 SOLD
Cylinders, 2 150 SOLD
Exhaust Pipe, stock SOLD
Hood 200 SOLD
Master cylinder assy Sold
Mountain handle bars, with hand warmers Sold
Oil Pump Sold
Stator 150 SOLD
Track, 156 Camoplast 250 SOLD
Twin Pipes, PSI with chip 275 SOLD
Vanamberg tappered tunnel and front bulkhead w/rolled chain case 350 SOLD
Windshield 25 SOLD
Brake caliper 100
Brake rotor 40
Case, Engine 200
18T gear 10
40T gear 40
Chain 10
coil 50
Computer 300
flywheel 70
Fuel pump assy 150
gas tank 50
Headlight assy 50
idler wheels 5 each
pistons, 2 100
Skis, ZR both 100
speedo 50
Spindles 50
Tach 50
Throttle bodies 50
Boss Seat SOLD
Hood 200 SOLD
Oil Pump Sold
Stator 150 SOLD
Windshield 25 SOLD
