Parting out 03 800 159 RMK
fastlane
Heres a list see if there is any interest in the parts basically its the entire sled, it did have lots of good parts, PM if interested, I will get some prices, if there is not alot of interest I might just fix it. Thanks
03 Ves 800- locked up rod bearing. 500 miles on new cylinders, pistons, crankshaft, did not grenade, caught it in time, needs cases machined, crank work etc. everthing else is good. Would sell complete with carbs, primary, electrical etc.
Brads one piece motor plate- new
Arctic cat roller secondary
chaincase, chain and gears, 20/41
Jackshaft
SLP pipe and can- ceramic coat
Boondocker NOS, 3 lb cylinder, fill tank, complete system
Grey belly pan- good shape
Bulk head and tunnel- straight has sno eliminators in running boards
Hood- vented, no head light, had front driving lights, camleon paint job
Fox float front shocks- like new with pump
Stock trailing arms
Radius rods, tie rod ends.
Simmons skis- red and black
159x 2.25 ported track, like new no rips or tears, not too many miles
159 Stock skid, 2 wheel 8'' big wheel kit
Stock blue seat- has tear
Fuel tank
Oil tank
fuel pump
handle bars
brake lever
throttle
steering post
Skid plate
bumpers
Im sure there is more if anyone needs something not listed Im sure I have it.
Sorry for the delay, most if it is sold, heres what is left,
Hood
Belly Pan
Wiring harness
Jackshaft and Rotor
Seat
fuel pump
coolant and oil reserviors
coolant hoses
motor mounts- 2 new and 2 used
Rubber carb jet holder with 340s, 360s, 370s, 500s, 520s
set of 62 gram primary weights.
There might be some other misc stuff I can think of.. PM if you need something.
