parting 2003 mountain cat.
7
76FOMOCO
Updated 4-01-08
For sale off a 2003 mountain cat that was a complete sled carbed.
All O.B.O. Plus you pay shipping! Shane 208-861-1008
Boss seat hi-rise with Nos pouch SOLD
Motor with SLP Port Job and cut .010 heads with 135psi each cylinder with 2k miles no flywheel, stator, or recoil. Includes water pump and oil pump no valves.1500.00
40 mm rack carbs 120.00
Single stock pipe 15.00
2 Factory cans 5.00 each
Black hood with 2” crack on right side next to the base of the windshield 185.00 local pickup only
Stock air box 25.00
Complete rear skid with anti-stab kit and cut rail tips for 151” pick up only. 375.00
Wild child forward mount post 2’ taller 150.00
Front shocks 125.00 each
Primary clutch 145.00
Secondary clutch 100.00
3 stock 70.5 weights 25.00
3 stock 71.5 weights 25.00
V 3 reeds 100.00
Chain case 50.00
Jack shaft 20.00
L upper and lower A arms 75.00
R upper and lower A arms 75.00
Gas tanks 50.00 local pickup only
Oil tank 10.00
Stock steering post 25.00
L spindle 15.00 SOLD
R spindle 15.00 SOLD
Stock 43 lower gear (new) 20.00
Stock 41 lower gear (new) 20.00
Stock 40 lower gear (used) 20.00
Stock handle bars SOLD
L belly pan silver 45.00
R belly pan with front dump (06 kk stock exhausts ) in rough shape 45.00 will sale just front dump parts
Gray belly pan 40.00
Gray front bumper 20.00
Black rear bumper SOLD
Stock long tail flap 15.00
Stock Y pipe 25.00
Stator and fly 200.00
Wiring harness engine 25.00
Wiring harness ecu SOLD
Ecu 120.00
Fuel pump SOLD
Coil 15.00 gone
SLP cold air intake box top only 45.00
Bulk head and tunnel with snow eliminators, 151 Early build with late build cooling local pickup only. 200.00
Coolant tank and cap SOLD
Recoil assembly with hi tensile rope 90.00
Early build servo cables 20.00 pair.
Tail light SOLD
Brake line 40” slp 40.00
Stock brake line 5.00
