Sensitivity Adjustments
To adjust the sensitivity, open the display module by removing the small Phillips screw in the back. Start your machine. Turn the lower potentiometer counterclockwise until the light starts flashing, and then turn it clockwise until the super bright LED turns off.
This is the most sensitive and thus more prone to pickup normal engine harmonics as knock. If after riding you feel yours is setup too sensititive, you can adjust the sensitivity slightly clockwise (ususally one or two hash marks will suffice). Hitting the rev limiter can also be picked up as knock.
Thats all it says for adjustment. In the back there are two pots. The upper one is for relay set point and the lower one is the sensitivity. If you want to control boost etc let me know and I'll post those directions etc.
M5
