L
LT
i have a virtually brand new paragon clutch. has maybe 40miles total and 0 miles since it was gone through. this fall had duane watt at hi-tech go through it and did all updates as well as clean and check/replace bushing,rollers ect. comes with directions/washers for the jackshaft as well as a keyed shaft hub. it has a splined shaft hub in it right now.
my number is 218-280-6366 ask for levi
320-693-9289 is duane watt's number if you have any questions for him. he is very helpful with everything!
the clutch retails for close to $1000 if my memory serves me correctly. asking $600OBO. OPEN TO OFFERS! needs to go people
this is the info from the website:
Over seven years in development and testing, the new Paragon driven clutch from Hi-Tech Performance is like nothing you’ve ever seen before!
This is the next generation in CVT clutching. You’ll experience a smoother and faster upshift and backshift, longer belt life, more horsepower to the track and easier tuning than ever before. The secret is the super torque load sensitivity of the power shaft (which can be interchanged to fit any brand of snowmobile). This unique design allows the sheaves to shift parallel to each other (no twisting), which produces a much better shift pattern than on conventional driven clutches. The results are nothing short of amazing.
The Paragon is built to take the huge horsepower, but can also be used on smaller horsepower machines. It is truly the top driven clutch on the market, and will be the last driven clutch you’ll ever need.
Over 7 years in development and testing
Quick, smooth and responsive
upshifting and backshifting
(like you’ve never experienced before)
Runs cooler, belts last longer due to
the parallel shifting sheaves
Transfers more horsepower to the track
Quick-change power shaft
Adjusts to many belt widths
Simple tuning - no extra cams to buy
External belt deflection adjustment
No machining required! Bolts on!
