PAR 13.6:1 Head for Pro RMK 2008-2014 - $295
Power Addiction Racing head will fit 2008-2014 Polaris 800 CFI.
Best suited for 5k and above elevation.
This is a direct bolt onto your sled.
Came off of 2011 800 Pro RMK. Only had this installed for about 200 miles.
About a +10hp increase over the stock heads in the mid range and 4-5 hp on top end!
This is simply one of the biggest bangs for your buck!
Designed to work around running pump fuel in your sled - no race fuel required unless you are at low elevation.
No fuel controller is needed to run this.
Call or text - 2zero8 8seven0 2five08
Email: timbre243@gmail.com
