P85 primary clutch
Hello all,
I am new to this forum, and have afew questions.
I have a 2000 700 XCSP and need new primary clutch.
What year, and model of P85 clutch will fit this sled?
Also, it has a stock cal white primary, with 10-60 weights
What s he spring rate(white) and is there a good upgrade I should consider?
Engine is stock, track has 96 studs.
Thanks for your help!
Gyver
You can use any 700 or 800 big block clutch through 2005. You can also actually use the 700/900 IQ clutch (2005-2006).
If it ran good with the white spring in it, just put a fresh one in and go ride.
sled_guy
