Does anyone know where to find a p-85 that will fit the 07 800R with the ring gear or have any drawings or dimensions that I could use to build one.
Thanks.
Thanks.
Winterbrew--Relay your experiance with the P-85 on a 07 800R.
WB seems to have his 07 800R rocking--he has a clutch kit that makes those 07's clutch issues--disappear!! I rode that thing--and it seriously rips!! Tried getting him to swap sleds with me---NO GO. I was bummed.
H20SKE...
If some of you riders are flat landers you might try the Polar primary from Polar Motorsports. They don't seem to have any issues out on the trail.
This will be my second season using the Polar primary in the mountains in BC. I have broke just about everything on the clutch but they design a cure and the clutch keeps lasting longer each time. I have the latest and greatest Polar on the sled now and ready to run.
I don't agree with a light clutch weight causing crank problems as light flywheels on bikes never hurt anything. Most race applications have as light a flywheel as possible, just enough to start the vehicle. In any case the Polar is at least as heavy as the TRA now, and Polar will drill the fixed post to bolt on the TRA ring gear as well. I don't use the ring gear.
The Polar is an amazing in the increase in performance, and you just run whatever stock secondary you have. Set up is easy and it doesn't need any adjustment when I ride from 2,800 ft to 9,000 ft.
Anyway if Polar has beefed up the primary enough I'm thinking BRP should get all the mountain sleds delivered with Polar primary clutches. Certainly would stop all the clutch tuning problems BRP has had.
* I think Polar is on the right track, but come on, no adjustment needed in a 5000+ ft elev change...
