The slot the weight fits in on the moveable sheave, will wear into the V mentioned. If you look at the material around the weight pin, on either side of where the weight sits, thats the region that wears. I have a clutch with a lot of missing aluminum in that region, lesson learned the hard (expensive) way, but now I have a new clutch! Placing shims between the weight and the aluminum gives you a cheap part to change as a maintenance item instead of wearing the moveable sheave. If the wear isn't bad, you can square up the aluminum top to bottom and add shims as needed. If a lot of grinding is required, there is a good chance the weights gauged the spider, and it would be advised to rebalance or replace the clutch.
One of the most crucial primary clutch maintenance items is belt to sheave clearance! So keep them clean, keep the spider shimmed properly, and keep good bushings in the weights. Helps them last much longer.
