I've been meaning to measure these side by side for a while, for anyone that was curious. I know some guys are snapping these off in the crank...
If the photos don't show up, please let me know.
That's an excellent theory TJ and was/is likely affecting some units more than others. I do think there are a good handful of issues with the P22 that are contributing... I like it but it sure needs help. I managed 1800kms on my original P22 before I took a new one on warranty (I shipped that straight to you). My Ti bolt has over 2200kms now, new one going in tomorrow. Balanced, lapped and indexed with a few little tweaks, mines doing well so far this year. I'm running a 2023 P22 (original spider)... for meow.Polaris offers a clutch bolt, like the Titanium one shown, solid to set the clutch at 150 Ft lbs then put the taper stock bolt on at 100 lbs...Crazy. The stock bolt is a Grade 8 and be torqued to 140-150 and leave it....Torque the clutch on with stock steel bolt then take it out and put in Ti ai 80-90 lbs is all they say....I would be afraid to use the Ti bolt is it breaks off you wont get it out...My Theory on the clutch falling off is the oil they coat the steel areas of the clutch to be shipped over on container to keep from rusting. then they never clean them at the factory before installing. Just a theory....The clutch wont set with oily surface...thus it start spinning and unscrews the bolt. We send Lapping compound with every P22 we balance to sue before installing back on...becoming an issue with some many....
Why? Why would you want to do something different than recommended by the factory?So if I pull the clutch on a new 9R to lap it onto the crank, when re-installing can I just skip the installation step of using the separate bolt, and just torque the original bolt back to 110ft/lbs? I think I have seen separate posts where you recommend going to 125ft/lbs….
Why?
NGL, it doesnt appear the factory has much on lockdown. So its not all that reliable lol.Why? Why would you want to do something different than recommended by the factory?
Ahhh. Good question. I didn’t look at it that way. I’m picking up what your putting downI don’t want to necessarily want do something different. I’m just wondering if lapping addresses the root cause and negates the need for that step. Curious to know if @carbontj still deems that a necessary step in his installations.
I would do torque at min of 140 ft lbs...150 wont hurt either...So if I pull the clutch on a new 9R to lap it onto the crank, when re-installing can I just skip the installation step of using the separate bolt, and just torque the original bolt back to 110ft/lbs? I think I have seen separate posts where you recommend going to 125ft/lbs….
i looked yesterday and the part spec shows a 10.9 grade bolt. are these the new ones?I heard yesterday that Polaris is sending out NEW Black clutch bolts. Not heard what the torque spec is but I would bet 150 ft lbs...
Yes....that just about Military grade....those cant be cheap.....i looked yesterday and the part spec shows a 10.9 grade bolt. are these the new ones?
This is what I'm seeing on the parts fiche. Usually there's a note saying the part number has superceded a dofferent part number, but not on this one.Yes....that just about Military grade....those cant be cheap.....
